hahha felling stupid now?? j/k lolZenkiCam wrote:ahhhh, i thought you were replying to me since i mentioned the NEO. my bad.. i misunderstood..
you are missing the point. it's not welding the collar on there. it's welding to add metal mass to the crank then turning it on the lathe. it's stronger and it's solid and look like it came out of nissan oem factory. i'm not referring to welding a slip on collar. a slip on collar is tighten down by the allen bolt. you get the idea ?s14 2510’s wrote:If one welds the crank colar on there expect to have the crank checked for trueness. I got my crank colar for around 70 shipped from somebody who made them. I still have his adress. He had the cad program to have these made. If you want his adress I can give it to you. I might even be able to find his email adress if I look into my old emails. It shouldnt cost much to put the crank in a lathe and have the old one machiened off. My cousins did it for free at there shop. When I had the crank checked for balance after I redid the colar he said he hardy had to do anything but he did drill 2 spots. I had him repolish the journals too because I was buying acl calico bearings for it too.
Im just saying welding isnt the olney way. Your 150 plan to fix isnt that easy. But its a start. Im just trying to make a guy think of everything involved in doing the fix so people dont get over there heads. Some nood will read it and be "wow i can fix it for that cheap".Anything to help somebody have a short NRRBA membbership there dues are crazy lol jkBoostsFed wrote:it's stupid if you build your motor without having the crank ballanced.
The topic here is the collar. balancing is a different story, therefore I didn't bring it up.
+1 I can't believe my buddy talked me out of going LS1!!!Kamin wrote:its expensive. you need to talk to your machine shop for prices because they will be doing the labor for you probably (unless your comfortable doing engine assembly/disassembly)
and my ls1 swap was hard, but worth every minute, and every penny. i wish i would have known this years ago i never would have messed with my RB25.
