sjbsuperman1425 »
https://forums.nicoclub.com/sjbsuperman1425-u80456.html
Tue Aug 30, 2011 6:12 am
Ok, i noticed the past couple days when i hit a certain RPM, the tachometer will sometimes jump erratically as well as the aftermarket oil pressure gauge. i bought the gauge and sending unit used awhile back and when idling or under normal load, it will read fine. This only happens when in boost and heavy load.
my question is, what would a failing oil pump look like on an oil pressure gauge? Im 99.999% sure its a faulty gauge/sending unit but I would like a second opinion on the matter as i've never experienced a failing oil pump and I dont want to be doing 80+mph at 5000rpm's and destroy my engine. thanks for the input.
