Morph wrote:
Awalys the bearer of bad news.
damn.. I did it again...
sl87 wrote:wait wait. dont i just remove the valve cover, drop oil sump and remove the four bolts on top and bottom of the cover then remove the front face bolts??? godammit theres more??
As much as I would love to tell you you are right... The short and painful answer is no.
In order to remove the oil pump, you have to remove the upper oil pan, which will not come out of its place unless you either 1) drop the subframe or 2) unbolt the engine mount and lift up the engine high enough (might still not give you enough room). You will see what I mean when you attempt this. This is why changing out the front cover is a big ***** if its inside the car. Also why, I ALWAYS recommend people to pop in a new front cover BEFORE the swap.
Also, you might (will) damage the part of your HG that goes between the front cover and your head. It is ultra tight there and when you go to put your front cover back on, it might (will) ruin the HG. But since this is not crucial to sealing of block and head, you might be able to get away with it. It's a big pain to get it to not crinkle when you try to put it in.
good luck and make your FSM your best friend.
