Queamore »
https://forums.nicoclub.com/queamore-u4368.html
Sun Feb 16, 2003 10:21 am
Ok well next, lets try checking the vacume. I just finished a car today with that problem and it had all the same symptoms. Start the car and listen very carefully for a sucking sound like something is sucking in air could be very slight so you'll have to listen carefully. and visually inspect all the vacum lines you can and make sure they are all in the right spots. Some guy messed alll her stuff up. He mixed the vacume lines up and it cut off and ran like an old car. If that doesn't work check the electrical, ignition, grounds, alt, plugs fuses in the engine. Let me know what you find.
