Oil Pump / Collar Destruction
SillyRB
Recently i had sold my RB25DET. The motor had made in the high 500 hp range. I sold the motor after i had a oil pump failure. The guy (Matt) who had bought my motor sent me a picture. Thought i would share it.Can you say snap ?
Imissmyturbo
Car: Car's, Turbo's, sking
Dam... I think RB's should come down in price because of this. It seams like you should replace your oil pump and drive collar on any RB motor that is not an R34 or R33 GTR. That means a teardown and crank removal.
Imissmyturbo
Here is an idea. If someone would make an oil pump that had the drive extented onto the crank more then you would have a bolt on solution.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
how freakin hard are you people pushing the motors? stock or in these instances are the hp ratings over 300hp?
Carl H
i think that one was making the better part of 500whp......
SillyRB
The motor this oil pump came out ogf was making 560-580ish.
gawdzilla
Car: none
Imissmyturbo wrote:Here is an idea. If someone would make an oil pump that had the drive extented onto the crank more then you would have a bolt on solution.
that isnt really possible. if you look at the crank, the notched area which drives the pump is just too short, and the rest of the snout is rounded and smooth. there is nothing for an extended oil pump to grab. only real solution is to mod the crank
