Kaikias »
https://forums.nicoclub.com/kaikias-u30397.html
Fri Aug 26, 2005 8:32 am
When you buy a timing chain gasket set it comes with an oring and a gasket for the oil pick up. When I replaced the front main seal last month I replaced the gasket bucause I didn't see where the o-ring goes. Now I am getting an oil light when I start the car as well as low oil pressure when I rev it past 2500 rpm. Just wondering if I should have put the o-ring on the pickup tube or is there just a gasket?
93 240sxka24de
