dtowngoalie »
https://forums.nicoclub.com/dtowngoalie-u121363.html
Fri Sep 25, 2009 3:51 pm
I have an rb20 in my s13, runs pretty good but my oil pressure is concerning me. I have 50 psi at cold start at 1000 rpm , 20 psi at hot idle at 900rpm, and 40 psi at 2.5k. The 40 psi hold until about 4k, but after that I take her up to about 7k and she drops down to about 28 psi. This happens under all load conditions. (neutral, accelerating, wot, and decel. When I decel from 6k rpm to 4k rpm, my oil pressure actually goes up.I have a small dent in my pan by the drain bolt, but I know the pickup is on the other side of that. It dent kinda slants over to where the pickup is though. Id say exactly where the pickup is, theres a half inch dent. My question for you guys is do you think this dent is causing this because the dent is restricting flow at higher rpms, or do you think I just have an old worn out oil pump... or, god forbid, something else wrong . Let me know what you boys think
