480sx »
https://forums.nicoclub.com/480sx-u50548.html
Wed Jun 04, 2008 4:45 pm
If you know how to replace your oil pressure sending unit, you should know where to check your oil pressure. Get a gage, and put it in the hole you screw the sending unit into.
Did you do anything to the motor other than install the drain and feed line for the turbo?
The pumps a PITA, its in the front lower timing cover. You have to take the valve cover, front timing cover, oil pan, crank pulley, then the lower timing cover.
