dontbugme »
https://forums.nicoclub.com/dontbugme-u28879.html
Fri May 05, 2006 5:20 am
I'd still try a mechanical gage as I don't trust electric ones.
The oil pressure relief valve is built into the high pressure side of the oil pump housing. It's a spring loaded spool valve with tight clearances that prevents excessive oil pressure when the oil is cold. Since you have some oil pressure, although weak, I'm assuming the oil pick up tube hasn't become detached from the pump. The fact that you had less oil pressure when you started it cold, the day after you noticed the drop in pressure, could mean the cold oil pushed the relief valve open even more and is stuck in the bore. I don't think anything is stuck under the seat so thicker oil won't help.
You can gain access to the relief valve w/o having to remove the front timing cover, IIRC, though you'll have to drop the oil pan. The valve's held in by a by a round screw and spring. If it drops right out, it's not stuck, check the flat face of the valve and seat for and gouges, chips or cracks. Then check or change the spring that holds the valve closed to see if it has the right tension, free length etc.
While you have the pan off, make sure none of the piston oil squirters fell or broke off or that the crankshaft oil galley plugs on the foward and after end of crank throws No. 1 & 4, respectively haven't fallen out. Both of these scenarios are highly unlikely but easy enough to check. Also, check your con rod bearing clearances by trying to move the big ends on the crank up and down or left to right, you really shouldn't be able to move them but a few thousands of an inch and since you didn't hear any knocking I doubt this is the problem.
If none of these checks leads to anything, maybe it is your pump.
