Chris28 »
https://forums.nicoclub.com/chris28-u70836.html
Mon Sep 06, 2010 11:18 am
I think my oil pressure is too low. Actually, I know my oil pressure is too low...way too low. Cold start is around 20 psi per 1000 rpm, so it's usually around 55-60 while I'm cruising. Once it warms up it's around 10 psi for every 1k rpm, so I cruise with it around 30 psi. Now if I drive for more than say 45 minutes, the pressure drops way down. On the way back to school (about a 4 hour drive) I would look at it every now and then and notice that the pressure was always less than when I last checked. By the time I was within a few miles of school it was about 20 psi at 3k rpm, and once I got off the highway it idled at like 1 psi. Even if I tapped the gas I didn't see a change in pressure, it wasn't until about 2.5k rpm that it even got above 10. By the time I got to my apartment it was like 15 psi at 3k rpm, and it didn't even show any pressure at idle. I drove it a few hours later and the pressure was back, but by the time I reached my destination about 30 minutes away I noticed the pressure pretty low again.
It's probably been about 1800 miles since my last oil change, I'm going to change it asap. Right now I have Wal-mart brand 10W-30 in there, I'm thinking about upping the weight so it's thicker and keeps my pressure up. I haven't driven my car very hard since the last oil change. Granted I did go to a track event, but I only got about 10 laps in so it's not like I was hot lapping the car all day.
I don't think it's my pump since the pressure is fine at cold startup, so I'm guessing it's the oil. The oil level is fine but the oil looked a bit dirty, could dirty oil affect the pressure this much?
Thanks for reading the wall of text, I always seem to have the most basic questions and I end up writing a freakin' novel haha.
