oil pressure
pyrro
Car: 1990 300zx na
what is the normal oil pressure in a 90 z32 n/a mine is like 20 or maybe less... is this bad... :confused:
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
warm idle standard is like 15 psi, it should go up as the engine revs go up, and it should be higher when you first start the car
pyrro
Car: 1990 300zx na
so its not my oil pump, i changed the oil of my car to a 20w-50 but the knocinkg still goes on...
what could this be...
evildky
06 Nissan 350Z GT
if you read my post on your thread about the toickign you'll see I suggested it might be an exhaust leak at the head and nowhere did I suggest you change you oil, and at this point I suggest you change back to standard oil, the 20w50 is too thick for startup and that could lead to cold start oil starvation
pyrro
Car: 1990 300zx na
ok so what head gaskets do you suggest i saw some in ebay does it matter if they are for the twinturbo.. its the whole set...
evildky
06 Nissan 350Z GT
I never said headgasket, I said exhaust at the head, and that doesn't mean it's that exhaust for sure but if you use a piece of tubing to your ear and move it around you might be able to determine that location and evaluate if it's annoying enough to warrent the effort involved
