240s_are_the_best »
https://forums.nicoclub.com/240s-are-the-best-u138388.html
Sun Feb 28, 2010 3:29 pm
Okay. the overheating problem i have is i think an air bubble... but i was driving down the highway tonight and i look down at my oil pressure gauge and boom i lost alot of pressure. i usually have 45ish at cold idle and i have around 60-80 when i first start driving. and when hot i have like 15-20 and about 45 driving. the eghay oil kit i have came with a restrictor built into the oil feed flange, and i am kind of worried about starving the turbo of oil because of the low hot oil pressures and blowing the rear oil seal with the cold pressures if i drill out the restrictor. when i pulled my pan today i didnt replace the oil pickup tube gasket , could this cause such low numbers? or are those normal numbers? the car is a 96 with 210000 on it and im almost positive that it is the original oil pump. Thanks!!
