Oil Pressure
NissanFairladyZ32
Car: 91, Twin Turbo, 99 Miata 1.8L
What is good idle oil pressure ?
and what is good oil pressure on the highway about 60-65?
Is NA and TT oil pressure the same ?
mac_daddy
Car: 92 slicktop n/a
I have an n/a and when im in 5th cruisin on the freeway i believe its about in the middle. depends what the rpms are at and how hard you're pushin the motor. hope this helps you out
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
FSM states idle oil pressure on a warm engine should be above 11 psi at idle (I believe ideal is ~30, mine sits at ~27, generally), and oil pressure at 3000 rpms should be between 51-65 psi. All oil pressure tests should be performed while engine has no load applied (out of gear).
NissanFairladyZ32
Damn mine sits at like 45 psi at 65mph in 5th gear
maybe my sending unit is going bad
Hope its not the pump
Ace2cool
It's probably just the sending unit. That's what went out on mine. F***ers are like $100 a pop. Be sure to seal it with some white RTV. I didn't know and mine started leaking.
DCaff300ZX
Car: .
1993 CRP TT- Modified
Ace2cool wrote:FSM states idle oil pressure on a warm engine should be above 11 psi at idle (I believe ideal is ~30, mine sits at ~27, generally), and oil pressure at 3000 rpms should be between 51-65 psi. All oil pressure tests should be performed while engine has no load applied (out of gear).
Damn...my 201,000 mile motor still does a minimum of 20-25 psi hot idling, and 45-60 psi under most any load...50+ psi at freeway speeds.Thanks, Duralube...
alright2020
Car: 92 jeep wrangler with SBC
99 F250 with 7.3 on 25lbs
91 300ZX na>tt>na
03 G35 coupe
my 205k mile na woudl still hit 80 with fresh oil getting on it... that was a strong motor..shame rod bearing went.
