oil pressure
CoontDunker
Car: 1993 300ZX NA M/T
hey guys,I was wondering aroun where the oil pressure should be and how much it should fluctuatethanx
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
It needs to be above 11PSI at idle, and 51-65psi at 3000 RPM.
flfuzzz
Car: 91 Nissan 300ZX 2+2
If your oil gauge works like everyone elses, it'll move around alot. Sometimes it may register 0 psi and sometimes it'll register around 10 psi when at idle. In the morning when you start the vehicle, it should register around 60 psi and as the engine warms, it drops. The oil sending unit in the Z32 leaves a lot to be desired and causes a lot of worry.
