Oil Pressure sensor
cheap_sticker05
Car: 1994 Nissan 240sx VERT! 1995 240sx
I need to know if I can unhook the stock oil pressure sensor and if it will mess with the ECU? From what I have read all that it does is trip the dash light. I want to hook up my Defi sensor because it is more accurate. Sorry for the noobish question but I don't want any problems to come up.Rich-
missionsix43
Car: 1989 240sx hatch ca18det
It does not effect the ECU's operation. You may want to find out if it sets off an audible buzzer for the oil pressure though, that may get annoying.
cheap_sticker05
Well isn't it amazing what reading all the search results will do for you? I found what I needed. For anyone who doesn't want to read, yes you can toss the stock sensor out, it IS just for the light on the dash. I wouldn't do it if you don't know how accurate your gauge is.
missionsix43
cheap_sticker05 wrote:Well isn't it amazing what reading all the search results will do for you? I found what I needed. For anyone who doesn't want to read, yes you can toss the stock sensor out, it IS just for the light on the dash. I wouldn't do it if you don't know how accurate your gauge is.
Uhh.. wtf?
Look above your post.
cheap_sticker05
Sorry, I didn't see that.
nismoplsr
Why not just put in a T adapter and run both?
float_6969
yea, just T it off, then you can keep the stock dash light working and have your gauge. That's what I did.
kahlistrophic
Car: 92' 240sx base
float_6969 wrote:yea, just T it off, then you can keep the stock dash light working and have your gauge. That's what I did.
whoa, what size adapter are you using, wouldnt it be huge?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
my light works still and im using a new sending unit for my autometer gauge. i just wired both up to the sender, and tossed the old one. swear to god it works, i got to see it in action this moning before i drove my brother's car to work instead.
ceniack
Car: 1992 240sx Coupe
1993 JDM Nissan Caravan
2011 Subaru WRX STI Hatchback
2012 Subaru Impreza Hatchback
how did you wire it up?
