LEMHEAD16 »
https://forums.nicoclub.com/lemhead16-u7080.html
Thu Feb 23, 2006 6:48 pm
Yes sir, No switch no light, The switch works by grounding the circuit when OP is low. If you disconnect the wire it can't ground the circuit. IF you still have the switch installed I would keep it plugged in it doesn't hurt to have back up whe it comes to oil pressure.
Modified by LEMHEAD16 at 10:58 PM 2/23/2006
