virus77 »
https://forums.nicoclub.com/virus77-u14925.html
Mon Aug 08, 2005 12:45 pm
Its only really good for after an oil change so you know there is oil pressure, or if your car sits overnight and the oil happens to drain it will warn so you dont run your car dry. realistically the oil indicator comes on when its a bit late (5spi and under) so its a pretty usless gauge.
However my aftermarket gauge saved my motor on two different instances (hole in filter once, and drain plug fell off once) that the stock gauge hadnt picked up on because it only goes off when you are under 5 psi. So i recomend you get an aftermarket gauge. But a stock gauge is better than no gauge so get something.
