480sx »
https://forums.nicoclub.com/480sx-u50548.html
Tue Aug 26, 2008 4:09 pm
Nope. Stock unit sends an On/Off signal to the ECU saying that there is incredibly low oil pressure. The autometer sending unit is a resistor that tells pressure from 1-100.
If you want to keep your idiot light you need to remote mount it with an T fitting from your block. If you screw the idiot light directly into the oil T, its possible(likely) that it will snap off and drain all your oil.
