shar75 wrote:It's been a couple of weeks. Since then I have taken the car to the dealer and they said what everyone said they would. It's normal the gauge just reads high. direct qoute from service manager "Nissan engineers made this engine to be almost indestructable. If the oil filter expands from pressure or the engine is making internal noise. Then there is a problem."Even so my concern is that the gauge or sending unit is faulty. When the unit pegs out an eighth inch past the 120 mark in upper RPM's. it just doesn't seem right. So I ordered a 0 to 150 PSI gauge and installed it with the stock sending unit. The stock gauge appears to be correct at low pressure but not at high above 100 PSI. The difference of 10 PSI is showing. The manual gauge is only reaching about 115 at max RPM. It wasn't easy to take the photo with my wife holding the gauge, the smaller photo was at about 5500 RPM.
It still ticks me off though because the guy at the dealership in chicago where I bought the car. Has told me after talking with their head tech that the gauge or sending unit may be bad.The thought that I paid for a brand new car and the dealer where I live doesn't want to even check the sensor because he said "Nissan won't pay for the labor". Why did I buy the extra warranty if they won't fix something that has obviously been problematic in more than one type of car. I know I'm just ranting a little but it sucks.
My concern that the engine was running to high an oil pressure is at least relieved. I'm not sure what to do about the sending unit or gauge being possible bad. I really don't feel like driving over 50 miles to take it to the next nearest dealer.
Modified by shar75 at 8:09 PM 1/20/2008
Quick question,
Where did you connect this aftermarket gauge?
i need to know because i have a swapped VQ and i'm currently running blind with NO gauges and i DESPERATELY need to hook one up.
Pictures would be great Thanx
