Seems kind of low... I get around 22 psi idling between 900-1000 rpm (crappy grounds ) after 30 minutes of driving. I do have a brand new oil pump though.ILikeMy240sx wrote:
Im getting close to 12 psi during idle at 1000 RPM just like it should be.
I have a brand new oil pump as well. Why do you say this is low? Factory spec is 11 psi at idle so Im happy where Im at with 10W-30redtop91 wrote:
It's just lower than what I see is all. To a certain extent though you can never have too much oil pressure though.ILikeMy240sx wrote:
You both think 12psi is low pressure? That's probably true, but you're the idiot because you pretend to know what you're talking about.redtop91 wrote:I knew me and your mom had something in common.
yeah that's what i'm getting now also. when i look at nissansilvia.com ther also they have these readingsjr_ss wrote:At warm idle I'm around 20-25psi. Cruising at 80mph I see 55-60psi at 3500rpms.
