oil pressure question
pregmantis
I just installed an autogauge mechanical oil pressure gauge. When hot(idle) it reads 18psi and when i rev it high it goes to 60psi. Im using 5w50 castrol synthetic. I never used a gauge before and I was expectging higher psi's, does this sound normal?
pregmantis
sorry, its an 89 kae engine
pregmantis
can anyone help me?
240marcuSX
Car: E34 525i
E46 M3
I believe you are supposed to have 10 psi per 1,000 rpm.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Here is how to check oil pressure per the FSM.... After car is warmed up to operating temperature, rev the engine to 3000rpms and hold, the gauge should read between 60-70psi. It's ok if it's +/- 5-7psi beyond that. Like after my car is warmed up and I have been driving for about 30min or so I will rev the engine up to 3000rpms and the gauge will read like 54-58psi. That is normal since the engine has 163,000+ miles on it. Of course when you first start the car the oil pressure will be crazy high so don't let that concern you either. Bottom line at idle and operating temp the pressure should be around 16-18psi. Any lower than that then you can worry.
pregmantis
thanks guys, I changed all bearings bout 5yrs ago(but not driven often)
