oil pressure problem
turbo2nr
Car: 97 240sx (kouki)
so driving today seen the oil pressure gauge was bouncing from 40-60psi traveling in 5th @60mph..
i try to get on it to give it more oil pressure but it doesn't go past 60psi. and it still bounces from 40-60psi.
checked my oil b/c im due for a oil change.. turns out i was low, put in 1qt. and started the car up. the oil pressure seemed fine. reved it, oil pressure when to over 80psi. and it was stable.
drove for 1/2 hr mixed driving, and it started to do it again.. bouncing form 40-60psi..
im thinking it may be a spun bearing.. any other reason?
btw the gauges are defi. so is it a possibility that maybe the sending unit or something is bad? but i only does it some times.. and when the car is idling. its at 20psi stable oil pressure..
kpodj61240
Car: S14 Zenki
my gauge got moisture inside and did the same thing.
