I've experienced the same problem on well built, meticulously mic'd and plastigauged engines. The only thing I can say if the bearings are new, clearances are well within tolerances, camshaft bearing cradles are not worn, and there are no leaks, start looking at the stupid pump. I've had pumps that are not that good at regulating was the engine is warmed-up and that seems to be the case for you. If you've re-used your old, then you're crazy. But then again, I've put in new pumps and I've gotten the exact same problem you have. Changed pumps until the problem went away. It's just soemthing about remanufactured pumps that spooks me nowadays because it causes me to do repetitious work which is not beneficial to me at all.r34 gtr wrote:quite often when i start my car i hear a knocking from what appear to be the bottom of the engine. not a bad knocking per say, as in nothing that would really harm the engine ( i know what this baby can handle rod knock wise, believe me) but its kind of nerve racking. my oil pressure has been all over the place lately, pegs the gauge when cold, takes a really long time to stabilize to its usual "hot" pressure... it also doesnt register any oil pressure for about 30 seconds after the car starts, but often it sounds just fine. it could well be my crappy autometer gauge is on the fritz, but i was thinking it might be the oil pressure regulator on the pump? or maybe the pump itself is getting tired. it looked to be in perfect shape, only 40k on the pump (last time i checked on it - 8k ago). my gauge is less than a year old, which is why ive been hesitant to blame it on that.
anyway, let me know what you guys think. my friend (who knows nothing about cars) said "it sounds like your car is chopping wood." to give you an idea.... the knocking isnt much louder than my (incredibly noisy) injectors.
- Tim
The ones I get are $200 U.S. Some folks say they pay a little over $100 U.S. for theirs.Swedish Mike wrote:Mr Dee, how much does a CA pump cost in USA?
/Mike
The 200 USD is OEM right? That´s a really good price, we pay 400 USD here.boost_boy wrote:The ones I get are $200 U.S. Some folks say they pay a little over $100 U.S. for theirs.
Dee
Have you personally experienced fresh builds with oil pressure dramas? This high temperature when cold and tapering to low temperatures when hot seems to be common with a lot of engines. I've personally experience these situations and have been forced to eat labor charges due to such a situation. Experts will be quick to point out possible excessive clearances, but what happens when those clearances aren't excessive? This oil pressure crap is a touchy subject and with it, I am not too proud to the point that I can't take anyone's advice on the subject.Swedish Mike wrote:
/Mike
I´ve only changed oil pump in the expensive engines, not CA with bearing swap and grinded crank. On these engines I normally just open up the stock pump and clean it.People never want to pay 400 USD extra without hp gains unfortunatly.boost_boy wrote:Have you personally experienced fresh builds with oil pressure dramas? This high temperature when cold and tapering to low temperatures when hot seems to be common with a lot of engines. I've personally experience these situations and have been forced to eat labor charges due to such a situation. Experts will be quick to point out possible excessive clearances, but what happens when those clearances aren't excessive? This oil pressure crap is a touchy subject and with it, I am not too proud to the point that I can't take anyone's advice on the subject.
Dee
Haha, good! Really nice reading, not often problems like this can be solved for free!boost_boy wrote:Tim my boy, Swedish Mike dear lad,
My issues with the oil pressure has been solved. After wondering if the engine has problem an wondering if I had gotten another skanky oil pump, I got desperate and took the 240 I'm building for yet another ride. Since it was the 2nd time I had opened-up the engine, I made sure before I reassembled that all tolerances were in spec, though this car is running a machined, balanced and polished crank.
So I took the car up the Florida turnpike enroute to the junkyard to pick-up a radiator for my turbocharged hyundai elantra and noticed the oil pressure only moving slightly higher than 25psi after 4000rpm. Now I'm saying, I built this engine right not only because of the amount of money involved, but the mere fact that I'm tired of pulling this motor in and out. I figured if the oil pump is really bad or the engine is out of spec, the low oil pressure will destroy the engine.
I drove the car back home with the same results. I left the car running and removed the oil pressure cap and "voila" oil was spraying out of the cap onto the turbo (No oil pressure problem there). Removed the turbo's incoming oil line and a powerful stream of oil was present. So frustrated with this crap, I pulled the oil pressure sending unit (autometer) off my sentra, connected it to the 240 and this thing now has a gang of oil pressure being displayed via the gauge. Took it for a ride, 2-stepped it, scared people, got the car sideways, and just down right dogged it, and that oil pressure is at 80psi by 7500rpm.
So in short, go after the sending unit; it worked for me.
Dee
