NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Thu Apr 14, 2005 3:19 am
I read through your post in infiniti, near the end it begins to make absolutly no sence. fisically it is impossible for that engine to have high[quite high] oil pressure at idle yet under accel, higher rpm, it drops below the idle pressure to the point it turns the light on. This is physically impossible, if anything your high rpm pressure should exceed 100psi with that kind of idle reading. Keep in mind I do not do alot of work on the Q since I am in the nissan dealer but on a max during cold start up the pressure exceeds 100psi on a gauge. I would assume the Q on could start up would have similar readings. I would really like to know what kind of pressure this car has on a stone cold start. The fact this infinit tech supposed master forced a tester into a whole it was not meant to be in gives me chills and makes me lean toward telling you to find yourself a more competant Tech.
