Riedell »
https://forums.nicoclub.com/riedell-u187212.html
Tue Nov 08, 2011 7:57 am
Check your OIL.
If oil level checks good on your dipstick, then the oil pump is probably going bad. You may not be getting good oil pressure in your engine.
Another slight possibility is the oil pressure sender could be going bad or the wire connected to it is touching another wire somewhere or isnt hooked up.
