ferreed »
https://forums.nicoclub.com/ferreed-u9943.html
Sat Feb 26, 2005 8:43 pm
All,I just finished rebuilding my wife's KA24E in her '90 240sx. We broke the motor in, checked for leaks, and put about 200 miles on it and it's doing great, but I'm worried about the oil pressure. Manual calls for a minimum of 11psi at idle and 60-70psi at 3000rpm, and we're above spec, but what is normal for a new engine? I'm reading about 60psi at 3000rpm and 15psi at idle hot.
I'm worried that I may need to pull the crankshaft and have it ground .010 undersize for .010 oversize bearings. It measured out ok against the spec and didn't have any obvious damage so I installed new OEM bearings. Sort of kicking myself for not having it ground and polished now anyway....
Any opinions on using a high-volume oil pump or heavier weight oils to artificially boost pressure? I appreciate any help or guidance y'all can provide.
