oil pressure gauge
joe3180
Car: 89 240sx, S13 sr20det, silvia conversion
can anyone tell me where i can tap into in order to get the oil pressure gauge installed? i have a autometer mech oil pressure gauge. thanx red top sr20det
slow s13
Car: cars, photo, music
you can take out the stock sender by the oil filter and use that port, this has been discused before so if you search there should be plenty of info.
gtune4
Car: toonah
i could never find **** on this subject
slow s13
this thread is pretty good
http://www.nissaninfiniticlub....stall
robbbby
Like the other thread discusses you can put it to the left of the oil filter where the stock sender/switch is. Most likely you won't be able to put the sender right into the stock port because of it's size, I think it would hit the oil filter. You may have to relocate it with some sort of braided line. Plus I heard mounting it right onto the motor isn't to good for the sender because of thevibrations.
joe3180
thanx....that thread was alot of help.
