SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Tue Apr 26, 2005 6:56 am
At startup oil is thick which causes high oil pressure, it will reach the lower "normal" pressure level after about 20 min of driving.
If the needle doesnt move at all then chances are it was wired wrong or had a voltage spike that got the needle stuck at max. This happened to my Greddy gauge, I had to take it apart and push the needle back down.
I would go over wiring first, ignition, constants? ground.
