Oil Pressure Gauge Question
goalguy02
Car: '92 240
Anyone with an Oil Pressure gauge on an SR, is there a factory oil pressure sender I can use or do I need to use the sending unit my gauge came with?
Hijacker
Car: '92 240sx Convertible
'94 F-150
The factory sending unit is for the dummy light. It only senses when oil pressure falls to critical levels.For your gauge to function, you will need to use the sending unit it came with
silk240
Car: '92 white 240sx coupe w/ blacktop sr20det
is the gauge easy to install? im about to get one soon and cant seem to find a write up on the process.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Its pretty easy, mostly straight forward. I'm not going to keep my stock sensor since I've heard its useless, plus, I'll be monitoring it much better with my gauge.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
silk240 wrote:is the gauge easy to install? im about to get one soon and cant seem to find a write up on the process.
Did you even try to search the site? There is a write up, by someone from Georgia no less, with a step by step.
zerothread?id=275181
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
not only will it not work, I believe unless it is a Greedy gauge the thread end will not be correct....you will have to get an adapter, Heavy Throttle sells one for $32 that comes with the proper fitting and a steel braided line so you won't have to wory about vibration damaging your sending unit.
