davisk6 »
https://forums.nicoclub.com/davisk6-u55553.html
Fri Apr 13, 2007 5:32 am
I'm having a problem with my Defi oil pressure gauge on my SR. When we first installed the gauge, the sensor was bad. It didn't read any pressure at all. I received the replacement sensor the other day and now the gauge reads, but very low. Upon startup, it reaches around 10-15psi, but soon after it drops to around 5psi. Occasionally, it will drop to 0 when the car stops, but it will jump back up to 10psi. It's fairly inconsistent.
I also have a boost and EGT gauge set up and those are working correctly. The sensor is attached using the Greddy filter sandwich adapter. The stock oil sensor "idiot light" is not on and the engine is running fine. I have also not found any filings or other wear in the oil itself. Any suggestions as to what the problem may be?
