oil pressure gauge installation
Ludsdatnis
Car: 1995 Nissan pickup
Own a 1995 Nissan 4 cyl pickup. Looking to install an oil pressure gauge. Need advice as to what gauges and sender to use and how to hook one up.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I went a VDO gauge from http://www.egauges.com. Chose the gauge and it should tell you which sender you need. You will need a 27mm socket to remove the old pressure switch from the oil filter housing. You want a sender that has an additional spade terminal so you can reconnect the wiring for the warning lamp....otherwise the warning lamp will be lit all the time. The thread is 1/8" fine thread. The sending unit is rather large but will fit. Run a lead from the sender to the gauge. Run power and ground to the gauge, do this for the gauges backlight as well. Everything should be up and running.
Ludsdatnis
Thanks much.
