Oil Pressure Gauge Install....
50DegreesSideWays
Whats up every one...?
I am getting ready to install an oil pressure gauge on my 91 240sx and was just wondering if anyone knows if it is possible to install the sending unit into the spot where the stock oil pressure switch is??
If it is possible where in the hell is the switch?? i have an idea but not completly sure...
Is it the unit next to the oil filter with one wire coming off....
Thanx
"Willie-B"
Night
Car: working on my car
i dont mean to be a prick but if you looked a little bit you will notice that there is the anwser one this board.
LilGold240sx
Car: 93 Mercury Villager DS (i.s.o. 89 240-coupe)
If you are installing the same kind I am, be sure to replace that plastic tubing with copper. Less change of breakage that way (and being scalded in the process of said breakage). :icesangel
MikeS14240sx
Car: 98 Nissan 240SX
I asked the same question and someone gave a very helpful answer, use the search option.
50DegreesSideWays
Yeah... i checked out that thread... Im gonna get an adapter and some other stuff pretty soon...
