oil pressure gauge install help ??
sr20det
Car: Drifting, draging, silvia projects
i was wondering if the stock sr20det redtop oil pressure sensor works with the oil pressure gauge since its a one wire connect???:help
QuinGarcia
yeah i have the same question!! I am trying to run an autometer electrical oil pressure gauge on my sr20det and I dont know if i can use the factory idiot light sensor, does anynoe know of a way to do this, or what i hafta do?
chezina
It doesn't work with gauges, cause it's only a pressue switch that gives out a signal when the oil pressure gets below a certain point.
SpeedRacer1
Car: 1990 240SX, G35
You could always try to pick up one of these for the install http://www.nissport.com/catalo...tType If the electronic sensor is compatible with this unit.
QuinGarcia
thanx for the help guys, i just pulled the filter adapter and bypass assy off and tapped it for 1/8 npt since im not retaining the factory idiot light anyway. thanx for the help
rob9246
can you explain that proceedure a bit moredid you tap a fitting on the factory block or are you refering to a sandwhich plate for oil cooler?
rob
Quick240
Or you could just buy an 1/8" NPT to 1/8" BSPT adapter for about $5.Take out the factory oil pressure sensor, screw in the adapter, then screw your new pressure sensor into the adapter.
QuinGarcia
I had no idea that 1/8NPT to 1/8BSPT adapters were that easy to find!!! I've never seen any BSPT stuff at any hardware store IVe been to. What is BSPT anyway????? Is BSPT like the rest of the world's version of the American NPT? What does it stand for?Rob, yes I just pulled the factory sandwich plate off by unscrewing the four metric allen head bolts that hold it on. I then disassembled this plate completely (removed o-ring seals and pressure regulator spring and check ball) and just used a 1/8NPT tap to enlarge the 1/8BSPT so it would fit my autometer gauge sender's threads. The 1/8BSPT is actaully about .020" smaller in diameter than 1/8NPT, but they share the same thread pitch, so you can enlarge the hole without screwing up all the threads. I then reassembled the sandwich plate's internals and screwed a 90 degree elbow into the newly enlarged hole (this is neceessary because the electrical autometer sender hits the oil fliter unless you use the 90 degree elbow) and screwed my gauge sender into that. Thats it! Oh yeah, you should remove the starter and oil filter for all of this, it makes it sooooo much easier to do.
Quick240
QuinGarcia wrote:I had no idea that 1/8NPT to 1/8BSPT adapters were that easy to find!!! I've never seen any BSPT stuff at any hardware store IVe been to. What is BSPT anyway?????
Autometer makes one. Also can be found at McMaster-Carr.Both have them on their websites.http://www.autometer.comhttp://www.mcmaster.com
Can't remember what BSPT stands for at the moment....
rob9246
hm this sounds like you would prob need to remove the intake manifold?
rob
QuinGarcia
Nope, I definitely did not remove my intake manifold, just the starter and oil filter
QuinGarcia
I have the engine on a dyno right now, so I had easy access. But you should still be able to accomplish what I did my removing the starter and oil filter, and working from underneath the car.
