Oil pressure gage
nismo300zx1990
Car: 1990 300zx NA
So anyone eles have this problem. When my car is cold my oil presure gage works great. however when my car gets warm it no longer works. now i know i have oil presure when it is not working im just wondering if it is a easy fix or electrical problem.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
replace the sender unit, they are known to fail. 30 min job, located above the oil filter.
nismo300zx1990
Car: 1990 300zx NA
Will do thank u
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
itsa300zx wrote:replace the sender unit, they are known to fail. 30 min job, located above the oil filter.
This.
Shoey2
Car: 1990 300ZX Fairlady Z Twin Turbo
just replaced mine last week, with the identical issue. easy to change and cheap as well even from the dealer.
johnshop
Car: 1995 nissan 300zx na 2+2
sorry to take over the thread, but i won't wanna make another one, hopefully is ok :D
it is any good to maybe add and aftermarket gauge for better readings? or it is just a waste of money?
nismo300zx1990
Car: 1990 300zx NA
Its totally ok i was thinking the same thing but i still want stock one to work
t.mcginley.jr
1966 Ford Mustang
You can go aftermarket if you really wanted, but the stock one works just fine as long as the sending unit is good. Once you replace the original sender with a new one it should be good for a long while.
Eli sharp
Car: 89
z32 tt
myne does the exact same thing as it warms up it drops out ..new one coming ...
