dhen »
https://forums.nicoclub.com/dhen-u100551.html
Thu Mar 28, 2013 7:07 am
OK, I think this is probably no big deal, but I figure better safe than sorry.
I have a rebuilt engine that I'm still breaking in. It's at about 700 miles. It has very good oil pressure - 70 PSI @ 3,300 RPM. I ran it through the gears a bit, revving it a lot, yesterday.
On my way home, the oil pressure dropped a little from 70 down to 62 at 3,300 RPM. This is still normal according to the FSM, but lower than usual. A couple of minutes later it was back to normal. Idle PSI was good - 25-30 PSI.
Any idea what happened? I'm using cheap non-synthetic oil, the coolant lines to the turbo are blocked off, and I don't use an oil cooler. The temperature was normal and the engine sounds fine.
My theory is that the oil heated up, thinning it out and then cooled off, but I'd like to hear what other people think.
