catchit89 »
https://forums.nicoclub.com/catchit89-u33095.html
Fri Oct 07, 2005 3:12 am
I ask you a few days ago about the oil light comming on , so i took your advice and left the car in the yard and installed a oil pressure gauge in place of electric also replaced oil pump before replacing oil pump my pressure starting was around 70lbs.started the car 3 times after about 15 mins the pressure was 25 and would not go past 45 on raising rpms. Ended up leaking dowmn to 0 not good car is not getting hot at all and not even using any fans. Changed oil pump man did have good pressure went up to 80 on start ended up staying around 25 lbs but would go to 60 everytime on rpms being raised the care now seems fine ran for good 30 mins so i decide to rd test as soon as i put it onthe rd the pessure drops down to 0 like nothing flat , a friend said it might be not using nissan oil filter dont think so i have read two other links one saying could be head gasket backwards are hairline crack but compressin is in high 160s another one had 3 loose head bolts , Mine is also gurgling as he said in his article is it tme to pull the head are could vaccum on exhaust be a part of it. I really do appreciate this site and some of the 240 proffessors . this car is from aprevious owner can you please give me some idea where i can begin dont mine where will do it myself . thankyou pete
