XTCshri2222 wrote:cool, I am useing the original block oil restrictors, but i am getting oil out of a brand new GT28, there is oil in the intake piping and some even comming out of the BOV. I asked around, most people said the turbo should be fine, but excess oil pressure could forced it way between the seals, since the turbo only has 6miles if that on it. I did follow proper break in withe new turbo. One of my friends who ones a shop said if it squeezed oil out between the metal seal, it'll keep leaking unless i take it apart and clean and dry it.
It's a brand new GT28 off a S15 spec r, i had it shipped from nissan japan, came in the oem nissan box, I did have to clock the turbo a bit, but that shouldnt cause any leaks being the seal is metal?
Is it possible if I hit 100psi, the factory oil restrictor was not suffiecient to reduce the oil pressure into the turbo?
The only way you will see your engine produce up to 100psi of oil pressure if you're revving it while it's cold, so try not to rev it until it's warmed-up because technically, no one shouldn't be revving their turbocharged cars at start-up, even though I do and I still don't experience the issues you guys are having. If this problem persist, you may want to pull that snail off for inspection or at least take off the cool side intercooler pipe, clean it up and try it again to see if indeed the turbo is still leaking.
If you are using the factory restrictor, this should have been sufficient enough as it is not on the turbocharger's chra or lehman's terms it is restricted before the turbocharger, so oil should flow freely through the turbocharger, thus not being restricted which should any possible build-up of oil pressurewithin the turbo's cartridge.
Dee
