OwnerCS »
https://forums.nicoclub.com/ownercs-u161666.html
Thu Sep 20, 2012 8:09 pm
When removing the pressure sensor to check using a conventional sensor, there is the British Standard Pipe Thread fitting required. Also, I used a pressure sensor tool to remove the old sensor before I PMed it. Checking pressure using the pressure sensor is not an easy task.
