yellow_jacket wrote:It has nothing to do with pressure. The stock sending unit is placed where it is for a reason. It needs to be in the coolant flow to read accurately. A little delay could easily result in severe overheating.
Once again, the gauge in no way controls the operation of the engine's cooling system. In no way would even a total gauge failure, or the ECU's coolant temp sensor failure, cause the car to overheat. An erroneous gauge reading yes, engine overheating, definetly not. The temp sending unit for the ECU and for the cabin gauge sit right next to each other in all DE engines. If the system is pressurized even if the sensor sits outside of the stream it will still recieve the same coolant at the same temperature that a sensor IN the stream would recieve. Hot coolant flowing out of the head will flow into ANY cooler space due to physics, this includes any area that has been Ted off. In no way will it be blocked off, let me see if I can computer draw this thing........ Autometer l l l l------- l------- l l l l l Stock Gauge
If this T is directly connected to where coolant would flow out of the head it would see just as hot a temperature as a gauge sitting directly in the flow of it, what with this hotter coolant being pulled into every available space both by the water pump, internal system pressure, gravity, and the temperature difference. However, I suppose all this is a mute point as I have developed another sytem which DOES place the sensor in the flow of coolant in the upper radiator hose, I found the solution on an old FD board, but physics and chemical dynamics is always tons o' fun!!!
