S13HatchKa24DET »
https://forums.nicoclub.com/s13hatchka24det-u43506.html
Fri Dec 15, 2006 10:02 pm
I have a 91 KA-T at least 80,000 miles on it (no sure the real amount). I was driving it the other day and when I went to start it up I had no oil pressure, I didn't realize it until I had pulled out of my driveway so I turned around quick and pulled in my driveway but before I shut it off my oil pressure kicked on. I let it sit a day, then started it up and had oil, drove it a little while, shut the car off. When I started it back up no pressure. I let it sit a day then started it up and it had pressure. Did the same thing though. I decided that when the car is still warm it won't have pressure when I start it up, but I am not sure if my pump is going bad or if it could just be a clogged filter. I would appreciate any help or suggestions. Thank you
