oil press sending unit
tubakins
Car: 89 240sx fastback
im installing a oil press gauge and i was wondering if i can use the factory oil press switch or do i have to tee it off and use the autometer one?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I've been told you can simply remove the stock oil pressure sensor and put an aftermarket one in for the gauge, since the stock one serves no other purpose than to make the little red light go on when something horribly bad has already happend. Dont do it on just my advise though, wait until someone who knows first-hand can shed some light onto the situation.
VitaminT
Car: 93 240sx SE
Kindof off topic but note...autometer oil pressure sensor in the Greddy relocation kit makes a big mess. With all the proper BPT-NPT adapters and such it leaks like a mofo between the adapter and the Greddy plate.
Solution...forget the teflon tape/paste and use black RTV sealant in place.
2Fass240us
Car: 93 240SX SE w/redtop
If you want to keep the stock sender, buy a Nissport (or equivalent) adapter and screw both the stock sending unit and the one for your gauge into it. Otherwise, buy an adapter and use the aftermarket one in place of the stock sender. I plan on doing the latter of these two things when I hook up my GReddy Warn oil pressure gauge.
Luke
2Fass240us wrote:If you want to keep the stock sender, buy a Nissport (or equivalent) adapter and screw both the stock sending unit and the one for your gauge into it. Otherwise, buy an adapter and use the aftermarket one in place of the stock sender. I plan on doing the latter of these two things when I hook up my GReddy Warn oil pressure gauge.
That's what I did and it works great.
Here's the link in case anyone was interested:http://www.nissport.com/catalo...tions
gsxrbg
we just installed the megan racing ol press. gauge in our company car (white 240sx w/sr20det redtop) and we used a t since its so close to the filter it was kinda tight but the t only cost 7 bucks and you dont have to stare at that idiot light all the time.
brian,boneheadperformance.comparts&powdercoating
