Oil press. question
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
im installing an oil filter adapter to run my oil temp and press gauges. would i want to use Teflon tape on the threads of the two sensors and the other to caps to the oil filter adapter so i dont leak oil?
superJoy
Car: 1989 RS13
I wouldn't use teflon tape in that situation, it's been known to break off and possibly clog lines/passages
Permatex makes high temp liquid thread sealant, you can buy it at any parts store. I believe that is the 'correct' thing to use in this application
sjbsuperman1425
CA18DET
but the bottom line is, i should use some sort of sealant, correct? i know the stock Oil pressure sensor didn't have any sort of sealant on it when i removed it before. thanks for the reply.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Yeah get you some sealant. I used teflon tape, but whatev.
sjbsuperman1425
CA18DET
alright thanks, i have to head to Advance Auto tomorrow anyway..the rubber connector piece for my boost gauge cracked over the winter so i need to get a new one, and i'll pick up some sort of permatex sealant when im there. thanks. vid coming soon
mazikowski
Car: 2013 Subaru BRZ Ltd 6MT, 1984 CA20E 200sx, 1981 L28E 280ZX
I used teflon tape too... just made sure it wasn't sticking off the edges of the plugs and sensors... left a thread or two untaped on the end and i've had no problems...
float_6969
Tape is fine, you just need to be careful applying it. I do plumbing a lot for my job, and there is definitely a knack to it.
I mostly apply it in a taper, with one wrap at the start of the threads and then increasing the # of wraps as it goes up. That will usually prevent it balling up and breaking loose.
bentvalves
Car: 89 Silvia K's
the most important thing to remember when applying teflon tape is to wrap it in the direction of the threads, not reverse of the threads.
sjbsuperman1425
CA18DET
ks13 wrote:the most important thing to remember when applying teflon tape is to wrap it in the direction of the threads, not reverse of the threads.
that would be the same way that you tighten it right?
sjbsuperman1425
CA18DET
i ended up just using teflon tape. and its working good.
i do have another question though. my oil pressure was between 30-50psi after warmup at idle..should i be checking for something?
bentvalves
Car: 89 Silvia K's
yea that would be the same way you tighten it
sjbsuperman1425
CA18DET
thats what i figured, so its all good now
im still wondering about the oil pressure though..
zero_gripS13
Car: soon to be 95 s14 hopefully
warmed up u should have 51-60psi at 3000 rpm..at idle more than 11psi
sjbsuperman1425
CA18DET
alright thanks man. you've helped me quite a bit lol
i am desperately trying to get a video of the car driving soon, but i have to go rebuild the caliper i was hoping i didn't have to, replace the drain plug in the radiator, and a few other odds and ends type of things and i'll get it posted..i get to drive it legally in 3 weeks!!! hurray for me!
zero_gripS13
hell yea man. atleast ur in in your car im still waiting to most important peice my damn block lol. ment to get it today but well see gotta call em. he just got the sleave monday or tuesday so he said couple days machine work so im thinking tomorrow or friday and i start work monday i wanted this thing togother before i started work damit lol.. oh well..
yea if u need a copy of the fsm or soemthing let me know i got it and thats where i get the info at :P
and yea i just bought a new caliper when mine went out lol.. i went to the track day and i guess it didnt like ebrake drifs cause it started leaking so the next day i replaced it along with all new brakes since i had them waiting any ways :P
sjbsuperman1425
CA18DET
damn, hopefully you can get that shiz together and going soon! lol i've had my car for like 2 years and i haven't got to drive it once because i bought it as a shell...
i do have the FSM, but it said something about 78psi at idle or something and i was like wtf? so i thought i'd just ask on here since i knew i had a thread started already, just to be safe lol
as for my brakes..to get the car home from like 100 miles away, i had to use the e-brake to stop while getting towed on a rope/chain by my friends GMC Sierra at like 6am in October, FROST on the windshield lol it was cold and hard to see..
VNG704
I read somewhere that you shouldn't use teflon tape on the sensor because it needs a ground.
sjbsuperman1425
CA18DET
VNG704 wrote:I read somewhere that you shouldn't use teflon tape on the sensor because it needs a ground.
thats what i thought of AFTER i installed everything, but all the gauges worked good, so go ahead and use it!
float_6969
Pipe threads are an interference fit. Either the teflon tape was moved out of the way and the metal had direct contact, or the tape was smashed so thin in the threads that it didn't pose enough resistance to cause any problems.
And actually, it's possible (I don't know for sure either way) that T-Tape is electrically conductive.
sjbsuperman1425
CA18DET
i forgot to metion this, but i left a couple threads at the end of each sensor and plug without teflon..just so theres a slimmer chance of it breaking off and going through the oil filter/motor and so i get some sort of ground for the sensor.
