Oil Press. gauge
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
Just got a GReddy relocation kit. It has two ports on the block adapter for oil temp/press gauges to be hooked up. Does anyone know if the fittings that come with Autometer gauges, fits in the port on the GReddy gauge? Also, is there a difference aside from the obvious between mechanical and electric gauges? I plan to get a mechanical oil press gauge as so long as the fittings fit.
Thanks for the help
smokey240sx
autometer use 1/8 NTP thread. I was told that you need a NTP to BSPT adapter for it to use on the greddy relocation. I purchased on from summitracing but it seem to be the wrong size.
drifter_for_life06
Car: Daily: '16 WRX
Exocet
ill have to look into that, let me know if you figure something out. Im awaiting an email back from GReddy to find out. I just dont want to have to fork out the money for a GReddy gauge, when i can get the Autometer for 46$ from AAP
drifter_for_life06
Car: Daily: '16 WRX
Exocet
TTT...bump
drifter_for_life06
Car: Daily: '16 WRX
Exocet
bump bump
anyone?
jcquick
Car: 95 Nissan 240SX w/ S13 SR20DET
If you haven't had an answer, I'm going to install an Oil Cooler w/ filter relocation on Thursday 6/07/07. I already have the Autometer mech. Oil pressure and temp gauges. I'm going to need a certain sized fitting for the oil temp gauge since it uses a copper hose with a good sized probe. There is a Hose shop near my house and they carry everything for your steel braided lines issues. I'll let you know what fitting you will more than likely need.
