jt15833 wrote:is removing the spark plugs for no spark or so that its easier to crank it over since no compression? if its no spark id much rather pull CAS connector
Both, kinna.. With no plugs, the engine will spin FASTER with a MUCH lower load on the bearings (crank and top rod bearings...).
Might help to squirt a teaspoon of oil in each cylinder..
Might do the oil pressure light trick a couple of times. Have the oil pressure light off cranking for ~~ 60 seconds or so (not 60 all at once, like 20 20 20 ...). With no plugs, the starter is not under a lot of load..
