LV240SX »
https://forums.nicoclub.com/lv240sx-u273700.html
Thu Apr 20, 2017 10:42 pm
Hello, I recently bought a 1991 240SX with a stock KA24DE with a blown head gasket.
Leakdown test confirmed cylinder 4 had compression leaking into the cooling system with 25% leak while the rest were in the 7%-14% leakage range.
A compression test on cylinder 4 showed it had around 95 psi while cylinders 1+2+3 had around 165ish on a cold engine.
I had a machine shop check it out was told it would only need a resurface, valve/seat grind, and new seals so I had them do it.
So I install the head and car started up and idled great. Took it for a drive around the block and when I got back my cousin said it gave off a little puff of bluish gray smoke when
I took off and then again when I got to the corner and stopped and took off again. Pulled it into the garage and it had a barely visibly mostly grayish smoke which got worse when
I gave it a little gas and let off.
Took out the spark plugs and the plugs looked like the car was running a little rich and I happened to look down into the cylinders and saw that cylinder 1,2, and 4 have a bit of oil pooled
on top of the piston, #2 had the most, while 3 looked fine. I did a compression test while my cousin drove home to get his leakdown tester and got 170 psi on cyl 1 180 psi on cyl 2 165 psi cyl 3 and 170 psi cyl 4.
Leakdown numbers are 3% cyl 1 9% cyl 2 14% cyl 3 and 5% cyl 4. I could only hear a slight hiss out of the dipstick tube loudest being in cyl 3. No pressure leaking into intake, exhaust, that I could hear and no bubbling from the radiator.
After the leakdown testing I looked into the cylinders and now 3 also has some oil on top of the piston but it is the least out of the four.
I am kinda doubting its the valve seals since they were replaced by a machine shop that a few friends of mine have been using for years and have never had a problem with but I do realize its still a possibility.
I would appreciate any suggestions on what I could try next to figure out what is wrong with the engine or any ideas as to what might be causing my problem. Any help is greatly appreciated.
