catchit89 »
https://forums.nicoclub.com/catchit89-u33095.html
Mon Oct 31, 2005 5:57 am
I just got done doing the timing on my 89 need to raise the car loosen one motor mount raise engine till pan slides out make sure you are carefull when removing pick up tube are you will damage the screen i had to take down tube to remove pan most important be extra carefull when removing from head
