LMAO...what a visual.rseabrooke wrote:Oh don`t forget to remove the dip stick and oil!!
I'd put a bit of thread sealant on that, just to make sure too. But yeah, little brass plug.andrave wrote:NPT pipe plug. available for 60 cents at your local lowes/homedepot.
The two motors I have apart right now are a 91 and a 98. The 91 has the brace and a large diameter (2.5" aprox) pickup with full diameter pickup screen. The oil enterance into the pickup is still fairly small at aprox 3/4" by 1.25". The 98 has an egg shaped pickup with no brace. The oil enterance hole appears to be the same size as the 91. The big difference besides the shape of the pickup is the screen on the 98 is formed to the inside of the egg (pushed against the top) which would limit the actual filtering surface to the diameter of the oil inlet tube to the oil pump (aprox 3/4 - 5/8"). I would think the 98 style would more easily get clogged but if its getting clogged, you have big problems anyway. I will try to get some pix of the two tomorrow.BadMojo wrote:
I'm curious to hear more about the differences in the oil pickup design. I always thought they all were the kind that had two bolts and the brace. Have you seen the different designs on two DOHC engines?
Maybe it's an S13/S14 thing. When I look at the pickup in my FSM and in FAST, it's the one with the brace. I have a '93. I'll be curious to see what mine looks like when I drop the pan after The Thaw.IvanAtSPRacing wrote:
thanks, thats what I was looking for. Also, If I don't have access to a welder to weld a bung on, I was reading on ka-t.org that you can get a "bulkhead fitting" and use that instead. Is that correct?andrave wrote:NPT pipe plug. available for 60 cents at your local lowes/homedepot.
