oil pan ?
quiksilvia
Car: 95 s14 se
i got my oil pan yesterday but no gasket, is the sr one the same as any usdm nissans that i could get, or does anyone know where i can get one
BuudWeizErr
it's liquid gasket, you squeeze it out of a tube.
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
yea, that's how NISSAN did it from the factory, blue gasket Nissan part number 0002 (at least that's the joke around here) Zip Ties are P/N 0001
Paul
I H8 UR DSM
yep, liquid gasket
quiksilvia
Car: 95 s14 se
good stuff, my bimmer one was an actual gasket, so i thought id ask, ill be sure to get those parts, according to the official number of course, thank you gentlemen
BaliLover
DO NOT APPLY TOO MUCH!! I had to replace my oilpan when I got my engine (previous owner cut and rewelded it to keep oil directly under the sump, but lowered the amount of oil it could hold by about 3/4 of a quart) and when I got it off, I discovered large chunks of liquid gasket on the screen of the oil pickup. Use just enough that it's not going to ooze all over the inside of your block.
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
I use Zep Red or black for most everything, and just apply enough to make a strong seal. You're better off with a smaller bead that is doubled over and smeared all over your contact surface than one big fat one that will just ooze all over.
quiksilvia
Car: 95 s14 se
i did it with the blue crap
