oil pan
xiongbs13
Car: 1990 Nissan 240sx SE fastback, hard top 1990
what is the easiest way to change my oil pan gaset for a ka24e
S13FX
Car: '69 l20b Dimeski :)
Pull the damn engine and then do it unless you like really tight spaces and wanna get pissed off.
Sorry I just had to do it recently and I said I will never again do it with the engine in the car.
12Ounce
Car: 1993 Nissan Pickup KA24E
I just did it on a 1993 ka pup. One formed-metal crossmember (4 bolts) was removed to make the job easier (possible?).
driffter240
Car: 1991 240sx coupe
i did this a while back...
pop your hood...
unscrew the motor mounts at the crossmember
jack up the motor from were the transmission meets untill you have enough space to remove it it worked for me.
you can also bring down the cross member (4) bolts unscrew motor mounts bolts (2) hold up motor with a hoist and remove pan
