Kaikias »
https://forums.nicoclub.com/kaikias-u30397.html
Wed Jul 20, 2005 2:56 am
Ok here is what I have going on. Had a leak in the front main seal and at the timing chain cover. So I lowered the oil pan, oil pickup, crank pulley, distributor….and everything that goes with that. Put it back to together, and was getting really low oil pressure. For some unknown reason I didn’t replace the seal at the oil pick up. So I go to actually remove the oil pan completely (have to remove minor dents to). I can't seem to get the lower motor mount bolts off so I can lift the motor high enough. Anyone got any ideas on how I can remove the pan with out removing the motor mounts. Fyi I am going to do a write up with pics on removing the oil pan when I get done with. Oh yeah 92 ka24de.
